[mapserver-users] projection info request Nad83 & wgs84
David Armstrong
david.armstrong at ntlworld.com
Tue Dec 18 06:29:50 EST 2001
Could someone on the list please help with the correct projection info ,
i need to setup mapserver with the following projection , to help another
lister with a project
but as i am located in the UK i am not familar with nad83 , although it
looks as if i am learning !!
the principal maps are in nad83 ( not sure of the zone yet !)
i need to set up the output projection to nad83 ( i think )
then set the map layers to nad83
also required is to set one layer to WGS84 ( gps layer )
and hope it all fits !
anyone have a similar projection requirement that can give me the correct
projection info for the map file
any advice is appriciated
Kind Regards
Dave
