[mapserver-users] Problems with PHP MapScript and Tiles unde
WinNT 4.0
Hankley, Chip
Chip.Hankley at GASAI.Com
Wed Dec 19 11:25:37 EST 2001
Peter,
I was having a similar problem... have you, by chance, created a spatial
index on the layer using SHPTREE? This was the case for me. If I deleted the
*.qix file, it worked; with it there, Doc Watson.
I believe that the guys at DMSolutions found a bug related to this and fixed
it (this was after your 10-15-2000 *.dll). So, you'll either have to
re-compile or wait for a new dll.
Cheers!
Chip Hankley
-----Original Message-----
Sent: Wednesday, December 19, 2001 8:31 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Problems with PHP MapScript and Tiles unde
WinNT 4.0
Hi Steve!
I'm using PHP MapScript 3.5 (php_mapscript_35.dll date 2001-10-15).
If I use the following Layer in my Mapfile (which works using the CGI)
LAYER
NAME Rivers
TYPE Line
STATUS default
DATA l_wl
TILEINDEX tiles
# MINSCALE 1000
# MAXSCALE 150000
CLASSITEM 'layer'
LABELITEM 'name'
LABELMAXSCALE 25000
CLASS
EXPRESSION /^q$|^qm$|^qo$|^qw$|^Q$|^QM$|^QO$|^QW$/
SYMBOL 'circle'
# MINSIZE 1
# MAXSIZE 5
SIZE 4
COLOR 100 100 255
END
END
The php_mapscript_35.dll produces a Dr. Watson error message.
The same layer without Tileindex seems to work!
Is there a special Version working together with tile or is there a Bug?
Many thx
Peter
Greetings from Austria / Europe
