[mapserver-users] Another Rosa applet question with CGI
Bart van Heijningen
bart at atsence.nl
Wed Dec 19 12:03:58 EST 2001
Hi all,
You were right about the errors.
The fact that I got the warnings/errors was that I changed my configuration
and compiled with the original configure. For RH however one needs the
ms34_configure-RH7-20010219_tar.gz configure patch.
After using this one all compiles fine.
I can run the compiled CGI but now I (still) do not succeed in passing
parameters from the rosa applet to the CGI, I cannot find any code examples
other than the ones which were posted earlier, they do not however list the
template file variables and use specific functions.
I cannot find examples for the ROSA which can be generally applied, as is
the case with the Mapplet which allows you to have a working setup fromwhich
you can work.
I would like to know what variables in the template file I should use to
pass to the CGI and a simple submit function.
I figure that if I can get a one (zoom) button to work the others will
follow.... I hope..
Regards,
Bart
-----Oorspronkelijk bericht-----
Van: frank at intevation.de [mailto:frank at intevation.de]Namens Frank
Koormann
Verzonden: dinsdag 18 december 2001 17:09
Aan: Bart van Heijningen
CC: Timothy.Mackey at agso.gov.au; perik at azimuth.nl;
mapserver-users at lists.gis.umn.edu
Onderwerp: Re: [mapserver-users] Another Rosa applet question
Bart,
* Bart van Heijningen (bart at atsence.nl) [011218 12:28]:
> Hi,
> This message is actually meant for Tim Mackey but anyone else is welcomed
to
> answer of course.
> I used Tim's mapserv.c patch for version 3.4 to compile the mapserver CGI
> for use with the rosa applet.
> I give you a rough idea about the compilation problems I encountered:
> mapsymbol.c and maplabel.c complain about unused variables like the
"Unused
> variable bbox, font and rect"
> mapraster.c complains bout drawGEN which is defined bun not used
So far this should only be warnings. All of them have nothing to do with
Tim's patch. I have set up a patch for MapServer 3.4 based on Tim's
work.
It can be found at:
http://www2.dmsolutions.ca/webtools/rosa/mapserver-rosa-patch.tar
or
http://www2.dmsolutions.ca/webtools/rosa/mapserver-rosa-patch.zip
> and some other errors which are most likely the result of these first few
> messages.
Does occur real errors during compilation? Can't you execute the
comiled binary? Please post more details.
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
