[mapserver-users] slackware
Frank Koormann frank.koormann at intevation.de
Fri Dec 21 06:32:09 EST 2001
* Vladimir Guzmán (vguzman at bigfoot.com) [011220 21:18]:
> Hello.
> I've tryied to install php mapscript in a Slackware Box.
> I've done everything I did when I installed it in suse, but it just
> doesn't work and I can't figure out why....
> Compilation seems to be fine (no errors), but when I try to load the
> dynamic module it says:
> Warning: Unable to load dynamic library
> '/usr//lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so' -
> cannot open shared object file: cannot load shared object file: No such
> file or directory in /home/sig/public_html/index.php on line 23
> And yes, the file does exist in the specified path.
Read access rights? AFAIR slackware default settings are more restrictive
than the ones on suse.
Regards,
        Frank
Frank Koormann                             <frank.koormann at intevation.de>
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
