[mapserver-users] How to Zoom out from an Extent and do a Query feature
Obe, Regina DND\MIS
Regina.Obe.PFD at ci.boston.ma.us
Fri Dec 21 09:27:52 EST 2001
I want to thank you all again for the great support I've been given and I've
been really impressed with the speed and functionality I have achieved using
mapserver and postgis.
Below is my first app that uses postgis and Mapserver and there was one
change that I have been asked to do. I'm not sure if it is easier to do in
the mapserver domain or Postgis.
I would like to generate a map view that is a 300 square radius around the
parcel that is being focused on or at least be able to zoom out from an
extent I give to mapserver
http://www.cityofboston.gov/dnd/REMSfind/PropDetailMP.asp?ParcelID=120138300
0
Right now what I am doing is using the postgis functions to list the nearby
available parcels below and the extent function to get an extent of the map
that contains the nearby parcels.
P.S. I apologize if it is a bit slow - the city hall's webserver is
sometimes a bit tempermental and also my SQL Server box is inside the
firewall (also since I was only allowed to have one port opened and not
allowed to install anything on the city's webserver I am querying the
Postgis server via my SQL Server box (using it as a linked server to SQL
Server). Surprisingly even in a linked server mode - the speed is pretty
decent and superfast in my intranet app.
The main page is
http://www.cityofboston.gov/dnd/REMSfind/FindProperty.asp if you wanted to
try a search of other parcels
Also if you wanted to list this application as a sample app using
postgis/mapserver, we would be very honored.
