[mapserver-users] mapserv: fatal: libfreetype.so.6: open failed: No such file or directory
Stephen Woodbridge woodbri at swoodbridge.com
Fri Dec 21 16:17:06 EST 2001
I do not think freetype version 2 is supported. I believe it has some
serious problems with respect to mapserver - check the list archives.
Also, do you have it in your LD_LIBRARY path or have you edited
/etc/ld.so.conf and run ldconfig.
-Steve W.
XSun at odu.edu wrote:
> Hello list,
> After I configure with the following option.  I got the following error.
> ./configure --with-gd=/dfs/home/x/xsunx002/soft/gd-1.8.4
>      --with-tiff=/dfs/home/x/xsunx002/soft/tiff-v3.5.7
>      --with-jpeg=/dfs/home/x/xsunx002/soft/jpeg-6b
>      --with-freetype=/dfs/home/x/xsunx002/soft/freetype-2.0.5
>      --with-proj=/dfs/home/x/xsunx002/soft/proj-4.4.4
>      --with-ogr=/dfs/home/x/xsunx002/soft/gdal-1.1.5
>      --with-wmsclient=/dfs/home/x/xsunx002/soft/w3c-libwww-5.3.2
> [Fri Dec 21 15:13:45 2001] [error] [client 128.82.243.101] attempt to
> invoke directory as script: /dfs/home/x/xsunx002/web/cgi-bin
> ld.so.1: mapserv: fatal: libfreetype.so.6: open failed: No such file or
> directory
> [Fri Dec 21 15:18:20 2001] [error] [client 128.82.243.101] Premature end of
> script headers: /dfs/home/x/xsunx002/web/cgi-bin/mapserv
> I am confused by this.  Can anyone help me ?  Thanks.
> Xsun
