Symbols in 3.4.
Stepan Kafka
stepan.kafka at oku-kh.cz
Thu Feb 8 09:08:26 EST 2001
Dear mapserver users!
I have several problems:
1. I tried new truetype line symbol support in 3.4. version, but the result
wasn't too nice (standard Arial "-" for dashed lines). Steve you wrote about
special truetype font for line features. It is possible to get it? Or what
is the solution?
2. With ITEMQUERY mode and using MAPEXT=SHAPE I would like to show the
result on certain scale, but BUFFER or SCALE parameter does nothing. I tried
the MAPXY=SHAPE, but with the same result. With point layers the result is
not usable.
3. In version 3.010 I use inline features this way:
In map file:
LAYER
NAME 'pin'
TYPE Point
STATUS default
FEATURE
POINTS END
END
CLASS
SYMBOL 8
SIZE 10
LABEL
TYPE truetype
POSITION cr
OFFSET -5 0
FONT arial
SIZE 8
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 220
END #Label
END # CLASS
END # LAYER
and thru CGI I call:
...&map_pin_feature_poits=-683920+-1065907&map_feature_text=something&....
It works well, but in 3.4. version I get error message "internal server
error". Where is the mistake?
Here is full URL:
http://www.oku-kh.cz/cgi-bin/mapserv?s=i&zoomdir=1&imgxy=&mapext=-686657+-10
68138+-681184+-1063676&imgext=-715708.120401+-1093562.000000+-661129.879599+
-1057286.000000&map=%2F%2Fhome%2Fhttpd%2Fhtml%2Fgis%2Fprojekt%2Ftopo.map&mod
e=browse&map_pin_feature_points=-683920.5+-1065907&map_pin_feature_text=&map
_web_template=topo.html&zoomsize=2&mapsize=450+300&qlayer=domy&layer=siln&la
yer=zelez&layer=cesty&layer=hran_l&layer=vrst10&layer=vodp&layer=vodl&layer=
mokriny&layer=les&layer=sidla
Thank you
Stepan Kafka
