Landview reference map
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Feb 16 10:23:40 EST 2001
There 's a bit more to it. The mapfile can be viewed at:
http://maps.dnr.state.mn.us/landview/reference.map
Note that this is not a traditional reference map, that is there
is no use of a REFERENCE section. Rather it is a second
map that is always rendered using the same map extent. The
thing that changes is the feature (i.e. a box or point) that is
added to the map via a URL.
If the scale of the main map is such that a box can be seen
then a feature is defined for the 'box' layer, if in real close then
a point feature is defined for the 'marker' layer, if way out then
neither is drawn. In practice I use javascript to construct the
URLs depending on scale.
The application found at this URL also uses this way of doing
things.
http://maps.dnr.state.mn.us/cgi-bin/mapserv?map=/usr/local/www/docs/compass/snowmobile/view.map&zoomsize=3&zoomdir=1&init=true
View the source in Netscape to see the resulting URLs for the
reference image or view in MSIE to see the Javascript.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Felipe G. Nievinski" <fnievinski at cpovo.net> 02/16/01 02:18AM >>>
The reference map definition (/landview/reference.map) has two layers
defining both the backgroung and the red box:
LAYER
NAME background
TYPE RASTER
DATA graphics/reference.gif
STATUS DEFAULT
TRANSFORM OFF
END
LAYER
NAME box
STATUS OFF
TYPE POLYGON
CLASS
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
END
Simply that.
Hope this helps.
Felipe Nievinski
UFRGS - Universidade Federal do Rio Grande do Sul
----- Original Message -----
To: mapserver-users at lists.gis.umn.edu
Sent: Friday, February 16, 2001 1:24 AM
Subject: Landview reference map
Hi!
OK, I'm stumped: how the heck does the LandView application
(http://www.dnr.state.mn.us/mapping/landview/) get the reference map to
display the red box in the mapplet? I'm trying to do something similar, and
am stuck here. Any help here is much appreciated!
Joel
