minimum hardware configuration (fwd)
teb teb at mallit.fr.umn.edu
Fri Feb 16 17:40:48 EST 2001
------------- Begin Forwarded Message -------------
X-Originating-IP: [132.236.154.76]
From: "David Raitzer" <david_raitzer at hotmail.com>
To: mapserver-info at lists.gis.umn.edu
Subject: minimum hardware configuration
Date: Fri, 16 Feb 2001 17:32:46 -0500
Mime-Version: 1.0
X-OriginalArrivalTime: 16 Feb 2001 22:32:46.0979 (UTC)
FILETIME=[62E85D30:01C09868]
Hello,
What is the minimum necessary hardware requirement for implementing
Mapserver on a Linux server running Apache, serving a 100 meg TIFF raster
layer, on which a simple point event theme is projected (sourced via an ODBC
connection to a Sybase database server)?  What is the hardware requirement
to serve the same purpose under NT with IIS 4.0? The site won't experience
truly heavy traffic, so it will probably rarely have more than 8
simultaneous users.  Thanks for any info.
-David
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
------------- End Forwarded Message -------------
