Passing lat/lon to URL
Douglas K. Rand rand at meridian-enviro.com
Mon Feb 19 15:34:59 EST 2001
Douglas K. Rand wrote:
> I'm working on a fairly simple map browser that I need to pass a
> latitude and longitude to another URL.  [...]
Stephen Lime wrote:
> I'm not quite sure I see the problem. If I understand right, then you're using
> the map for the user to identify a point correct? There are several ways to
> deal with this. The easiest I think would be to create a second, really simple
> map file that basically looks like:
> MAP
>   STATUS OFF # important, you don't want a map created
>   UNITS meters # whatever matches the projection
>   PROJECTION
>     .. set your projection ...
>   END
>   WEB
>     TEMPLATE "http://www.com/form?lat=[maplat]?lon=[maplon]"
>   END
> END
Right on the money. I hadn't considered using a different map. This works like a
champ (after I also figured out I need the image size in the form).
Thanks.
