a problem with mapscript
Tom Kralidis
tomkralidis at hotmail.com
Fri Feb 23 14:34:18 EST 2001
I tried this out using the ms_demo mapfile, and did not get an ioctl error,
yet a file not found error on a RedHat6.2:
[naboo:~/mapscript_test]{170}% pwd
/home/tkralidi/mapscript_test
[naboo:~/mapscript_test]{171}% cat ./test.pl
#!/usr/bin/perl -w
use mapscript;
use strict;
my $map = new mapObj('/home/tkralidi/mapscript_test/demo.map') or die
"Unable to open mapfile: $!\n";
my $img = $map->draw() or die('Unable to draw map $!');
mapscript::msSaveImage($img, '/tmp/imgfile', $map->{interlace},
$map->{transparent});
[naboo:~/mapscript_test]{172}% perl ./test.pl
Unable to open mapfile: No such file or directory
[naboo:~/mapscript_test]{173}%
a run with a -d switch gives me this:
[naboo:~/mapscript_test]{173}% perl -d test.pl
Loading DB routines from perl5db.pl version 1.0402
Emacs support available.
Enter h or `h h' for help.
main::(test.pl:6): my $map = new
mapObj('/home/tkralidi/mapscript_test/demo.map') or die "Unable to ope
n mapfile: $!\n";
DB<1> next
Exiting eval via next at (eval 7) line 2.
eval '($@, $!, $^E, $,, $/, $\\, $^W) = @saved;package main; $^D =
$^D | $DB::db_stop;
next;
;' called at /usr/lib/perl5/5.00503/perl5db.pl line 1239
DB::eval called at /usr/lib/perl5/5.00503/perl5db.pl line 1133
DB::DB called at test.pl line 6
What gives here?
..Tom
>From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
>To: <tomkralidis at hotmail.com>,<paul.jacobs at javel.nl>,
><mapserver-users at lists.gis.umn.edu>
>Subject: Re: a problem with mapscript
>Date: Wed, 21 Feb 2001 09:33:37 -0600
>MIME-Version: 1.0
>Received: from [156.98.35.249] by hotmail.com (3.2) with ESMTP id
>MHotMailBC5D2BBF00744004311F9C6223F93BE90; Wed Feb 21 07:37:36 2001
>Received: from DNR-Message_Server by co5.dnr.state.mn.uswith
>Novell_GroupWise; Wed, 21 Feb 2001 09:34:13 -0600
>From steve.lime at dnr.state.mn.us Wed Feb 21 07:37:40 2001
>Message-Id: <sa938b95.072 at co5.dnr.state.mn.us>
>X-Mailer: Novell GroupWise Internet Agent 5.5.3.1
>As near as I can tell this isn't a MapScript issue but is related somehow
>to
>communications- sockets, communications ports or console/shell. I haven't
>been able to track down any possible causes or fixes. Try searching
>Google for the phrase "Inappropriate ioctl for device" and you'll see what
>I mean.
>Steve
>Stephen Lime
>Internet Applications Analyst
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
> >>> "Tom Kralidis" <tomkralidis at hotmail.com> 02/19/01 09:51AM >>>
> >Hi,
> >i am trying to use mapscript (ms_3.4) and have the following problem.
> >Mapscript compiles ok and i am able to use the example files in the perl
> >directory. The problem is that i can't open any mapfile. $map = new
>mapObj
> >fails every time. Can anybody help?
> >regards
> >Paul Jacobs
>I have the *identical* problem. I altered the line which open the mapfile
>to check for errors, ie:
>my $map = new mapObj('/www/htdocs/gis/mapserv/wmp/wmp-dev.map') or die
>"Unable to open map file: $!\n";
>and get:
>Unable to open mapfile: Inappropriate ioctl for device
>..Tom
>_________________________________________________________________________
>Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
