SDE testers...
Eduin Yesid Carrillo
yecarrillo at hotmail.com
Tue Feb 27 11:47:33 EST 2001
Yes. I can help this effort testing MS with Apache/IIS4 WinNT4/Win2k/Win98
Sde3.0.2,3.0.2.1,3.0.2.2/arcSDE7.2,8.0 and all their possible combinations.
Additionally, you sent me past days the egon's compilation for SDE. I test
it with this results:
1. Egon compiled MS with ArcSDE 8.1 libraries. I have ArcSDE 8.0 .So, I move
this files to my cgi folder :pe80.dll, sde80.dll (renamed as sde81.dll),
sg80.dll. This files are required by MS when trying to run it form DOS
command line.
Effect of rename sde80.dll to sde81.dll is unknown.
2. Connection are established . Using the correct connection
parameters(cd,esri_sde,oracle,ciu_admin,ciu_admin), I found this error :
msDrawSDELayer(): SDE error. SE_layer_get_info(): 0â‚. (-20)
When change the password, the error becomes to:
msDrawSDELayer(): SDE error. SE_connection_create(): â‚. (-9)
3. I used one minimized map file to reduce other errors. I ask egon for
other funcionality parameters activated when compiled MS, because get some
errors of GD library with scalebar and labels. Probably because I'am using
png images to build the labels.
I hope this information will be useful.!
Bye.
Ingeniero Civil
CIUDAD DIGITAL
Central de Información Regional Georefenciada
Bucaramanga - Colombia
yecarrillo at condorito.uis.edu.co
#ICQ 14323531
>From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
>To: <mapserver-users at lists.gis.umn.edu>
>Subject: SDE testers...
>Date: Mon, 26 Feb 2001 14:41:36 -0600
>Could those of you interested in testing the new SDE functionality in 3.5
>contact
>me off the list? I'd like to set up a small group of folks to try the code.
>I should have
>it working later this week, queries and all...
>Steve
>Stephen Lime
>Internet Applications Analyst
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
