problems with ms_newClassObj
Dieter Lehmann
lehmann at fh-nuertingen.de
Mon Jan 15 11:05:01 EST 2001
Hi there,
I get stuck using mapscript/php3. With my attached code I get an "document
contains no data".
Think, something is wrong with the Class-definition.
(using only the map-file without the definitions of a class everything is o.k.).
Could someone help me?
Thanks !
Dieter
----------------snip----------
$map = ms_newMapObj("ex1.map");
$poLayer = $map->getLayer(0);
$nColorId =$map->addColor(244, 0, 0);
$poClass = ms_newClassObj($poLayer);
$poClass->set("name",testo);
$poClass->set("color",255, 0, 0);
$poClass->set("outlinecolor",255,0,0);
$img = $map->draw();
$url = $img->saveWebImage(0, 0);
printf("<IMG SRC=%s WIDTH=%d HEIGHT=%d>\n", $url, $map->width, $map->height);
----- and here the map-file ex1.map------
LAYER
NAME "test2"
DATA gmd
STATUS DEFAULT
TYPE POLYGON
END
END
___________________________________
Dieter Lehmann
University of applied Sciences
Schelmenwasen 4-8
D-72622 Nuertingen, Germany
Phone: +49 (0) 7022 404 Ext. 192 or Ext. 152
Fax: +49 (0) 7022 404 Ext. 166
