MS on OpenBSD
Chris Faulhaber jedgar at fxp.org
Thu Jan 18 11:14:39 EST 2001
On Thu, Jan 18, 2001 at 12:20:40PM -0500, Gerald Thornberry wrote:
> I've never installed MapServer, and I'd like to serve from OpenBSD 2.8.
> If anyone has any OBSD experience to share, I'd like to get your input
> before I go down that road.
Installing on OpenBSD should not be difficult (works well on
FreeBSD) as long as you have the correct libs installed
(most of which should be available via ports).  You may have
to tweak the linking stage if you plan on using the PHP
interface, though.
Chris D. Faulhaber - jedgar at fxp.org - jedgar at FreeBSD.org
FreeBSD: The Power To Serve   -   http://www.FreeBSD.org
