[mapserver-users] PHP/Mapscript module and Phorum
Rob Martinson
cathode at nichebox.com
Mon Jul 2 20:08:50 EDT 2001
I obtained and built the following
http://mapserver.gis.umn.edu/dist/nightly.tar.gz two days ago and the
class still exists. But, I also noticed that my version string is as
follows:
MapScript Version (Apr 3, 2001)
MapServer version 3.5 (pre-alpha) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=GDAL
INPUT=SHAPEFILE
Maybe nightly.tar.gz hasn't been updated in a while (from the date
above).
Rob Martinson
Nichebox - http://www.nichebox.com
Development - http://dev.nichebox.com
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Tuesday, July 03, 2001 2:49 AM
> To: Rob Martinson
> Cc: MapServer List
> Subject: Re: [mapserver-users] PHP/Mapscript module and Phorum
> Hi,
> Just as a follow-up, the query class is gone in MapServer
> 3.5, so this issue applies only to PHP MapScript 3.3.011 and 3.4.
> Daniel
> Rob Martinson wrote:
> > Just FYI for those of you that run Phorum PHP forums with
> mySQL (and
> > possibly others). You cannot leave your php_mapscript.so
> loaded at all
> > times with this or use it within the same script where phorum is
> > called. And if you're running Apache as standalone instead
> of through
> > inetd you will have additional issues. The problem is that Phorum
> > declares a query class which conflicts with a class of the
> same name
> > in the Mapscript module. What I have done is just gone
> through all of
> > their code and renamed the class so it doesn't interfere.
> > Rob Martinson
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
