[mapserver-users] Re: Mapscript/PHP and TIFF
Rupert, James
rupert at NRCan.gc.ca
Fri Jul 13 08:57:59 EDT 2001
Hi Steve and Daniel,
Thanks for the help, it was the GD problem. I had explicitly told PHP to
compile with GD 1.2 but noticed that the configure stated that it did not
have GIF support. This was because I had originally compiled PHP with GD 1.8
and did not remove the config.cache file. Once I deleted the config.cache
and reran configure and compiled and installed PHP and apache everything is
now working.
Now its time to learn how to use mapserver and PHP/mapscript to create a
layer and draw symbols that can be queried at locations from a postgresql
database. Any examples would be a great time saver
Again thanks for the help.
Jamie
> From: Stephen Lime[SMTP:steve.lime at dnr.state.mn.us]
> Sent: Wednesday, July 11, 2001 3:40 PM
> To: morissette at dmsolutions.ca; rupert at NRCan.gc.ca
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] Re: Mapscript/PHP and TIFF
> This is a GD issue. You must've compiled with a different version than PHP
> was compiled
> with. In GD 1.2 the image array in GD is column major (i.e. img[x][y]) and
> in subsequent
> versions they switched that to row major for performance reasons. Get the
> versions of GD
> in sync and I believe the problem will disappear.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Daniel Morissette <morissette at dmsolutions.ca> 07/11/01 02:27PM >>>
> "Rupert, James" wrote:
> > Hello Daniel,
> > I have encounter a problem with PHP/mapscript and TIFF images. If I use
> > mapserver standalone the TIFF image appears properly. If I draw the same
> map
> > file through PHP/mapscript the image is output as a mirror image and is
> > rotated 90 degrees anti-clockwise. Any thoughts.
> > Jamie
> Jamie,
> PHP/MapScript does nothing special about the way things are drawn. Are
> your 'mapserv' CGI and your PHP MapScript compiled with the exact same
> options? Perhaps one of them uses native TIFF support in MapServer and
> the other one uses GDAL's TIFF support? (If so then we'll have to find
> out why they behave differently.)
> Maybe Frank, Steve, or someone else on the list already ran into a
> similar problem and will have some ideas?
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
