[mapserver-users] Re: help w/ ogr/tiles
Daniel Morissette morissette at dmsolutions.ca
Tue Jul 17 09:41:00 EDT 2001
Drew wrote:
> Ok, I've got 3.5 built with ogr, and I've got the demo working. I made a
> data2 directory and put a few .dgn files in it, and pointed the demo.map
> to use that directory, and commented out all the old LAYER definitions.
> Like I assumed, the map comes up blank. I guess I need to know how to
> setup the layers automatically, since all my data is a few hundred
> tiles. I'm not even sure what layers are in those .dgn files, or what
> they're named, or how to call them. Any help would be appriciated :)
> thx
> Drew
Drew,
The reason why you see a blank map is likely that your mapfile extents
doesn't match (i.e. at least intersect) the extent of your layers...
that's a very common mistake we all make.  So you'll have to find out
the extents of your DGN files and set the mapfile extents.
About tiles, the OGR link will not currently support tiles the way we
are used to see them with MapServer.  This could be added (after 3.5) if
there is enough demand for it, but at the moment the only type of tiled
data that the OGR link supports is MapInfo "Seamless layers".
 DM Solutions Group              http://www.dmsolutions.ca/
  Don't put for tomorrow what you can do today, because if
      you enjoy it today you can do it again tomorrow.
