[mapserver-users] ScaleHint
Rob Atkinson rob at socialchange.net.au
Thu Jul 19 15:12:50 EDT 2001
Actually if you work this through you reach the conclusion that the service is the URI , with qualifiers to
the right of the ? if required, and the host is irrelevant, which is exactly what is supported!
Stephen Lime wrote:
> So after all the discussion the current behavior is correct, correct? That is the map is generated but
> the layer will not appear if the scaling limits are violated. Performance issues abound if this is not the
> case so I don't know of an alternative.
> On the map "vendor specific" parameter I just wanted to add that I think OGC missed the boat by
> not being able to specify a particular service on a host other than using the root of the URL (i.e.
> left of the ?). It's going to be pretty common for sites to host multiple applications using the same
> engine, MapServer, ArcIMS or whatever and maintaining the wrapper scripts while simple is a
> bit of a pain. Being able to refer to the service (in our case using a mapfile name) would've been
> a nice addition to the spec.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
Type: text/x-vcard
Desc: Card for Rob Atkinson
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010720/4a85c191/rob.vcf
