[mapserver-users] Works in Winnt but not Linux...
Janet Ciavarelli Jciavarelli at city.kamloops.bc.ca
Fri Jul 20 11:11:34 EDT 2001
Thanx everyone for your help.
It turns out I found a workaround. I'm still not sure why it didn't work the way it was
and the log files were of no help.
Janet
>>> "Ballard,Lowell" <LBallard at YesVirginia.org> 07/20/01 06:03AM >>>
Have you looked to see what Apache has to say about it in the log files?
Does it say anything useful?
-----Original Message-----
From: Janet Ciavarelli [mailto:Jciavarelli at city.kamloops.bc.ca]
Sent: Thursday, July 19, 2001 4:15 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] Works in Winnt but not Linux...
I have a particular line in my html file that works fine in WinNT with
Apache.
But this same line I cannot get to work in Linux running apache.
Here is the line:
<img border="1"
src="/cgi-bin/mapserv?map=/ms_demo/example8.map&amp;mode=map&amp;layer=city_
property&amp;layer=pothole&amp;layer=city_streets&amp;imgext=$ar{imgext}&amp
;imgbox=$ar{imgbox}&amp;imgxy=$ar{imgxy}">
I've tried modifying this line in several different ways. I've even tried
creating an error in the example8.map file and seeing if at the very least
it will choke on it. It doesn't even do that. It's like it's just not even
executing the mapserv executable. Yet I know the mapserv executable works
cause it is called properly on a "SUBMIT".
Any ideas why this line is not executing the mapserv command?
Janet.
