[mapserver-users] MapScript Perl-CGI/Problems
Vinko Vrsalovic B.
v at w.cl
Mon Jul 23 16:01:22 EDT 2001
> My perl script executes a print statement right in the beginning, so it is
> always printing some kind of output.
That's why I said: 'an error that prevents execution', for example
syntax errors.
> When I rum the script from the command line, I get a seg fault. If I take
> out the mapscript code, then it works fine.
I just tested your script with a map file of my own and it worked, so
the problem may be:
1.- Your map file
2.- Permissions of the file or the directory
2.5.- The header of the file (ie #!/usr/bin/perl missing)
3.- Your GD library (does it allow to generate gif's? may be you should try
with png's if you're not sure)
4.- A very particular conflict of your configuration :)
Good luck,
V. <v at w.cl>
