[mapserver-users] MS_PNG or MS_JPEG
Jim Burnett jimburnett at ntelos.net
Mon Jul 30 15:25:06 EDT 2001
I have the older GHD lib because I can use the mapserver compiled CGI script
with the demo.
I just was testing from PHP , and (tring) to return the image in an img
src=/.php tag.
Right now if I use jpeg, it seem to take forever to load the image, then
when it doesn finish, it display nothing. SO I went back to using gifs.
-jim
----- Original Message -----
From: "Puneet Kishor" <pkishor at geoanalytics.com>
To: "'Jim Burnett'" <jimburnett at ntelos.net>;
<mapserver-users at lists.gis.umn.edu>
Sent: Monday, July 30, 2001 2:34 PM
Subject: RE: [mapserver-users] MS_PNG or MS_JPEG
> Jim,
> Mapserver depends upon an external library called GD (available from
> www.boutell.com) for generating images. GD was initially developed to
> generate gifs, but when Unisys came down with their claim to gif, GD was
> modified to stop making gifs. If you want gifs, you have to simply look
for
> the older version of GD (methinks v 1.2 and earlier -- still available in
> many places) and compile Mapserver with that.
> pk/
> Puneet Kishor
> www.geoanalytics.com
> GeoAnalyics, Inc.
> 1716 Fordem Ave
> Madison WI 53704
> -----Original Message-----
> From: Jim Burnett [mailto:jimburnett at ntelos.net]
> Sent: Monday, July 30, 2001 10:29 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] MS_PNG or MS_JPEG
> MS_PNG or MS_JPEG
> int saveImage(string filename, int type, int transparent, int interlace,
>                  int quality)
>         Writes image object to specifed filename.
>         Passing an empty filename sends output to stdout.  In this case,
>         the PHP header() function should be used to set the documents's
>         content-type prior to calling saveImage().
>         Type can be either MS_PNG or MS_JPEG
>         Quality should be a value in the range 0-95, higher value implies
>         higher image quality and larger image sizes.
>         If quality is negative, then the default IJG JPEG quality value is
>         used.
>         The function returns -1 on error.  On success, it returns either 0
>         if writing to an external file, or the number of bytes written if
>         output is sent to stdout.
> no GIF support?
> -jim
