[mapserver-users] Changing feature points
Robert Aldridge bamarob55 at yahoo.com
Tue Jun 5 10:18:37 EDT 2001
I'm having the same problem with 3.4.  I tried the
suggestion below with no luck.
I get the following error message:
Internal Server Error
The server encountered an internal error or
misconfiguration and was unable to complete your
request.
Please contact the server administrator and inform
them of the time the error occurred, and anything
you might have done that may have caused the error.
More information about this error may be available in
the server error log.
Thanks for your help,
Robert Aldridge
--- Stepan Kafka <kafka at email.cz> wrote:
> Remove POINTS section in your map file. (I had
> similar problem with it and
> it helped me.)
> Stepan Kafka
> > -----Pùvodní zpráva-----
> > Od: owner-mapserver-users at lists.gis.umn.edu
> > [mailto:owner-mapserver-users at lists.gis.umn.edu]za
> u¾ivatele Mike Law
> > Odesláno: 4. èervna 2001 22:12
> > Komu: mapserver-users at lists.gis.umn.edu
> > Pøedmìt: [mapserver-users] Changing feature points
> > Greetings all,
> > I'm having some trouble with the MapServer 3.4 cgi
> processing a change in
> > the point values for a feature object.  I've added
> a form object
> > which adds
> > the following to the url:
> >   ...&map_postcode_feature_points=-79.97+43.45&...
> > to try and dynamically change the location of the
> symbol based on
> > user input
> > (which will eventually be drawn from a database,
> but that's going to be
> > implemented later).
> > When it is run (under Apache on Windows), I get a
> crash in
> > MapServer and an
> > Internal Server Error sent back from Apache.  I've
> copied the relevant
> > section from my .map file below.  I'm wondering if
> there's something that
> > I'm doing wrong here.  Thanks very much for any
> help people can give me.
> > cheers,
> > Mike
> >   layer
> >     name "postcode"
> >     postlabelcache true
> >     status default
> >     type point
> >     class
> >       symbol "place_ident"
> >       label
> >         angle auto
> >         antialias
> >         backgroundcolor 255 255 255
> >         buffer 1
> >         color 255 255 255
> >         font "arial"
> >         force false
> >         maxsize 9
> >         mindistance 15
> >         minfeaturesize auto
> >         minsize 9
> >         offset 6 6
> >         outlinecolor 0 0 0
> >         position ur
> >         size 9
> >         type truetype
> >       end
> >     end
> >     feature
> >       text "You Live Here!"
> >       points -79.87 43.25 end
> >     end
> >   end
_________________________________________________________________________
> > Get Your Private, Free E-mail from MSN Hotmail at
> http://www.hotmail.com.
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year!  http://personal.mail.yahoo.com/
