Also having problem with Rosa Applet and PHP4
Assefa Yewondwossen
assefa at dmsolutions.ca
Wed Mar 7 17:44:49 EST 2001
Hi There,
I have fixed the problem and it is commited in the CVS and will be available for
the next version of mapserver (3.5).
Later,
Doug Bryant wrote:
> Hello,
> I am also having problems with the Rosa applet and PHP4. I am using PHP
> version 4.0.4pl1 and Mapserver version 3.4. I will list compile options
> below.
> The problems I am having is different than the ones that Christian was
> having. I believe the problem is in the Rosa Applet. When the applet is
> turned on, using the gmap75 example, if it zoom in with a bounding box, from
> say Whitehorse down to Victoria and east to Winnipeg, the resulting map that
> is drawn is a very Zoomed in view of the border between the US and Canada
> just below Regina.
> This happens when I try to zoom in on any larger area. When I am zoomed in
> very tightly to an area, it seems to work properly, but that area is very
> small.
> If I turn the applet off, it seems to work properly and zoom in gradually,
> but the bounding box is not available.
> Any help or pointers is appreciated.
> Thanks, Doug.
> Here is my setup.
> Redhat 6.2. Apache 1.3.14
> PHP is compiled with these options:
> ./configure --with-interbase=/usr/local/interbase
> --with-config-file-path=/etc/httpd
> --with-apxs=/usr/sbin/apxs --enable-safe-mode
> --with-regex=system --with-zlib --with-gdbm
> --enable-debugger --enable-magic-quotes'
> --enable-track-vars --enable-sysvsem --enable-sysvshm
> --with-xml' --with-ftp --enable-dbase
> --with-pgsql=/usr/lib/pgsql
> Mapserver was compiled with these options.
> ./configure --with-php=/usr/local/src/php-4.0.4pl1 --with-apxs=/usr/sbin/apxs
> --with-gd --with-jpeg --with-proj=/usr/local --with-ttf=/usr/local --with-tiff
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
