Query map without zoom in
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Mar 14 11:02:10 EST 2001
Yup, don't use the mapext=shapes option. In that case it should default to the
extent of the previous map (i.e. the one the selection was done in). You may
have to explicitly set any zoom parameters (i.e. zoom or zoomdir) to a values
consistant with panning when the query is submitted.
Steve
>>> Armin Burger <armin.burger at territoriumonline.com> 03/14/01 04:07AM >>>
Is there a possibility using a query map (style highlite) but without
causing the map to zoom in to the selected feature(s)?
Im using a query map defined equally to the 'normal' map, i.e. the header
and footer defined under WEB object are producing a replica of the original
html document. My intention is just to have an identify function for
features on the map (with the attributes of selected features below) but
without always opening respectively changing to another browser window. I
don't know if there are any other solutions for this.
Armin
Armin Burger
Territorium Online
Siemensstrasse/Via Siemens 19 - I-39100 Bozen/Bolzano - Italia
tel: +39-0471-568185 / fax: -- 568078
_
