Querying capabilities
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Fri Mar 16 16:03:23 EST 2001
Yes, you can, Although I don't have examples.
Your web interface will simply provide a list of layers available to be
queried, such that the user can click a check box for instance.
The "NAME" for this parameter will be "qlayers" (Layers to be queried).
And yes you can specify a template for each, and then use the head and
footer to surround the whole thing (I.e. the HTML/BODY tags for example).
Hope this helps,
J.F.
> From: Kieran J. Ames[SMTP:kames at keyspanenergy.com]
> Sent: Friday, March 16, 2001 3:07 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Querying capabilities
> Hello list. I'd like to ask a question about querying.
> Does Mapserver support this...?
> I have several layers rendered via the map file: Points, lines,
> polygons, more lines, more points, etc. I only have one of them defined
> as being queried.
> Can I define several (with different query templates) and let the user
> select which he/she wants to view details on? If so, any examples out
> there?
> Thanks for all your help.
> Kieran
