automatilcally do pan
Andy Bernat
abernatj at yahoo.com
Mon Mar 26 11:05:06 EST 2001
Frank,
Would you be so kind as to explain how you figured out the image size
from the information in the url? I've been having some problems
getting my map to display the way I want and I'm sure it's because I
don't have a good grasp of what some of these parameters are and how
they are used by mapserve.
Thanks in advance,
Regards,
Andy Bernat
--- Frank Koormann <frank.koormann at intevation.de> wrote:
> Hi Bertha, Hi Listers,
> * bertha amalia serrato de la cruz (bertha_bonita at yahoo.com) [010324
> 00:31]:
> > Hello list..
> > I have a problem when i choose a layer and press the
> > bottom Refresh/Query show the layer choosen and
> > automatically do pan ...each time press Refresh/Query
> > do pan..
> > In the next result, i didn't press the radio button
> > pan
> > only i wanted view the layer
http://pc-simac.cicese.mx/cgi-bin/mapserv?mode=browse&zoomdir=0&zoomsize=2&layer=basaltos&imgxy=299.5+299.5&imgext=-657555.174556+-601360.777736+753555.174556+633360.777736&map=%2Fhome%2Fhttpd%2Fhtml%2Fgeoejercicios%2Finter02%2Finter02.map&savequery=true&mapext=shapes
> > i don't kown why take &zoomdir=0&zoomsize=2
> > how can i resolve the problem?
> For some reason I get no response from your web server. However, one
> of the
> first pitfalls in setting up a new mapserver application is to miss
> some
> geometry/resolution settings to be adjusted to your needs: I your
> case
> potentially some information on the image size. If these are not
> correct, the center of the image will be calculated wrong everytime
> you
> generate a new image. From your URL example I read that your image
> should have a size of 6000x600 pixel. If this is not the case, you
> should adjust your settings (in the map-file and the templates).
> Regards,
> Frank
> Frank Koormann
> http://intevation.net/~frank/
> Professional Service around Free Software
> FreeGIS Project
http://freegis.org/
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
