AZ-C SPCS definition
Chad Streck
chads at adci.com
Wed Mar 28 15:11:05 EST 2001
Thanks Frank. I used your values and changed units to ft and converted
the x_0 to feet by multiplying 3.28084, and my points landed about 200
miles east of where they should be. So I figured it was a +/- issue, so
I put a - in front of the x_0 and that shifted it about 500 miles west.
So for giggles, I used you meters calculation and the points land where
they are supposed to be, so I'm very confused at this time.
Here is what I have for the map file projection....
projection
"proj=tmerc"
"ellps=GRS80"
"units=ft"
"lon_0=-111.916666667"
"lat_0=31.000000000"
#"x_0=699999.9999972"
"x_0=213360.000"
"y_0=0.000000"
"k=0.999900"
"no_defs"
end
... and for the layer that is in lat/long....
layer
classitem "status"
# maxscale 1000000
# minscale 0
name "ace"
data "procon/ace-cust"
status default
type point
projection
geographic
end
class
color 0 64 128
expression /A/
name "Existing Customers"
size 8
symbol "hospital"
end
class
color 128 64 0
expression /B/
name "New Prospects"
size 8
symbol "hospital"
end
class
color 64 128 0
expression /C/
name "New Customers"
size 8
symbol "hospital"
end
queryitem "ddlong"
tolerance 5
query
expression /./
template ""
end
end
I have some imagery that is in AZ-C NAD83 FT that I will now place on
the vector data to see how far off I am.
Chad
Frank Warmerdam wrote:
> Chad Streck wrote:
>> I'm working on a application that will display points on top of
>> imagery. The imagery and the base data are in state plane AZ-C NAD83
>> FT, but the points I have are all lat long. I defined the projection
>> for the point file as geographic, and I'm trying to define the AZ-C SPCS
>> for the main projection, but I don't seem to get the proper parameters.
>> I know that my low understanding of projections is probably at fault,
>> but could someone please help in defining the AZ-C projection, or point
>> me to a good reference or cheat-sheet on it? I haven't been able to
>> find a good one so far.
>> I know I could just use ArcView to translate the point file to state
>> plane, but the future of the project will be using lat/long for the
>> points from an SQL database, so I need to get this projection working
>> sometime, and now would be a good time.
> Chad,
> I have this definition for Arizona Central, NAD83:
> +proj=tmerc +lat_0=31.000000000 +lon_0=-111.916666667 +k=0.999900 +x_0=213360.000 +y_0=0.000 +ellps=GRS80 +units=m no_defs
> Since you are using feet, you will need to translate the x_0 value to feet
> and change +units=m to +units=ft.
> Let me know if this works.
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
