[mapserver-users] query timeout problem
Tim Cera
timcera at earthlink.net
Tue May 1 22:20:02 EDT 2001
I have a problem and I hope that someone can help me.
Problem:
Time-out for a basic query against a point shapefile.
No error in apache error_log.
No error from mapserv.
No files in the mapserver tmp directory.
Tried with 3.3.011, 3.4. Tried the 3.4 version on Linux and Solaris
2.5. All had the same result.
Attached is the mapfile. Suspect that there might be a problem with
the shapefile, but nothing that ArcView notices. Can forward the
shapefile if needed to diagnose, didn't this time because of size.
thanks
Tim Cera
map
extent 1204767.875 -118660.570312 1295298.75 220208.359375
imagecolor 255 255 255
name "Uppergate"
shapepath "shapefiles/data"
size 600 600
status on
units feet
symbolset "symbols/all.sym"
# markerset "symbols/marker.sym"
# 1 scalebar #none
scalebar
backgroundcolor 128 128 128
color 255 255 255
intervals 4
outlinecolor 0 0 0
size 200 7
status on
style 0
transparent true
units feet
end
# 2 layer Counties
layer
data "countybnd"
name "Counties"
status default
type polygon
# 1 class Counties
class
color 255 255 128
name "Counties"
outlinecolor 0 0 0
end
end
# 3 layer Municipalities
layer
data "cityboundries"
name "Municipalities"
status default
type polygon
# 1 class Municipalities
class
color 192 192 192
outlinecolor 0 0 0
end
end
# 4 layer Water
layer
data "water3"
name "Water"
status default
type polygon
# 1 class Water
class
color 0 0 255
name "Water"
outlinecolor 0 0 0
end
end
# 5 layer Roads
layer
data "roads2"
name "Roads"
status default
type line
# 1 class Roads
class
color 0 0 0
name "Roads"
outlinecolor 0 0 0
end
end
# 6 layer {Property Lines}
layer
data "propertylines"
name "Property Lines"
status default
type line
# 1 class {Property Lines}
class
color 255 0 0
outlinecolor 0 0 0
end
end
# 7 layer {Gates and Barricades}
layer
classitem "MGT_AGENCY"
data "gates"
footer "gates_footer.html"
group "gates"
header "gates_header.html"
name "Gates and Barricades"
status default
type point
# 1 class USCOE
class
color 255 128 0
expression "USCOE"
name "USCOE"
outlinecolor 0 0 0
symbol circle
size 15
end
# 2 class MDWFP
class
color 128 255 0
expression "MDWFP"
name "MDWFP"
outlinecolor 0 0 0
size 6
end
# 3 class {Crow's Neck Environmental Center}
class
color 128 128 128
expression "CROWS NECK ENVIRONMENTAL CENTER"
name "Crow's Neck Environmental Center"
outlinecolor 0 0 0
size 6
end
# 4 class {City of Burnsville}
class
color 128 128 255
expression "CITY OF BURNSVILLE"
name "City of Burnsville"
outlinecolor 0 0 0
size 6
end
# 5 class Other
class
color 128 255 255
expression "OTHER"
name "Other"
outlinecolor 0 0 0
size 6
end
# 6 query #none
query
template "gates_query.html"
end
end
# 8 web uppergate.html
web
footer "uppergate_footer.html"
header "uppergate_header.html"
imagepath "/opt/htdocs/tmp/"
imageurl "/tmp/"
template "uppergate.html"
end
# 9 querymap hilite
querymap
color 255 0 0
size 200 200
status on
style hilite
end
# 10 reference graphics/reference.gif
reference
color -1 -1 -1
extent 1140681.27478 -238916.044756 1339354.9618 249581.561545
image "graphics/reference.gif"
outlinecolor 255 0 0
size 120 120
status on
end
# 11 legend #none
legend
keysize 18 12
status on
# 1 label #none
label
color 0 0 89
size medium
type bitmap
end
end
end
