[mapserver-users] temporary files deletion
Doyon, Jean-Francois Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Tue May 15 11:21:25 EDT 2001
I've discovered a small freeware implementation of "cron" for windows
systems:
http://www.kalab.com/freeware/cron/cron.htm
Simple and to the point, runs great.
For *nix's, on my Linux boxes I use the tmpwatch utility to clean out
temporary directories, including the ones that hold temporary gif's ...
RedHat comes with tmpwatch allready setup in it's default cron jobs anyways,
so you only need add to it ...
J.F.
> From: 	Speh Sylvain[SMTP:sylvain.speh at CLERMONT.cemagref.fr]
> Sent: 	Tuesday, May 15, 2001 9:56 AM
> To: 	Assefa Yewondwossen
> Cc: 	mapserver-users at lists.gis.umn.edu
> Subject: 	RE: [mapserver-users] temporary files deletion
> Yes, why not, but, what about mapServer under W95 which is not provided
> with
> a scheduler/chrontable ?
> Someone here was trying to use a VB script into an HTML page ( like some
> virus do ), but we could'nt achieve it.
> Any Idea ?
> -----Message d'origine-----
> De : Assefa Yewondwossen [mailto:assefa at dmsolutions.ca]
> Envoyé : lundi 14 mai 2001 22:01
> À : mapserver
> Objet : Re: [mapserver-users] temporary files deletion
> Hi There,
>  For those of you who use windows, there is an executable on our site that
> can be used to delete tmp files created by mapserver.
> http://www2.dmsolutions.on.ca/webtools/dl/deltmpfiles.zip
> Note : I did some initial testing but I will start testing it on our
> internal server begining today.
> Later,
> Assefa Yewondwossen wrote:
> > Hi,
> >  Does any one has a bat file or an exe file (or other means) that I can
> > use to delete files on windows based on the time of the files. I would
> > like to be able to delete tmp gif files generated by mapserver that are
> > older that x time.
> > Thanks,
> > Assefa Yewondwossen
> > Software Analyst
> > Email: assefa at dmsolutions.ca
> > http://www.dmsolutions.ca/
> > Phone: (613) 565-5056
> Assefa Yewondwossen
> Software Analyst
