[mapserver-users] itemquery INQUIRY (fwd)
teb
teb at mallit.fr.umn.edu
Wed May 16 09:45:11 EDT 2001
------------- Begin Forwarded Message -------------
Date: Wed, 16 May 2001 08:42:11 -0500
From: "Sonia Dickerson" <Sonia.Dickerson at state.mn.us>
To: <mapserver-info at lists.gis.umn.edu>
Subject: itemquery INQUIRY
Mime-Version: 1.0
Guten Tag. Ich bin neu bei WebServer und habe ein frage.
(I don't know much German but I enjoy the interaction with this
global mapserver community!)
Here's the Deal:
I tried to simulate the results of the Case 3 simple itemquery
with querymap Test from the DNR test suite.
I set up a directory that contains the data, graphics, perl, and
symbols that are actually just copies from the msdemo that can be
downloaded from the site. It also contains the iq.map file,
test.htm file and the case3_template.htm file.
The iq.map file is set up as follows:
I copied the map file from the case3 sample and named it iq.map
-it is also named test with in the file. I made a few
modifications to represent the county data names and the correct
imagepath. I have the same data set that the original case3
sample uses- so all of the fields and values are the same.
The test.htm file is set up as follows:
I copied the source code of the initial case3 html page and
deleted all of the code except for the stuff that pertained to
case3. I also made the value modifications.
The case3_template.htm is set up as follows:
I copied the template from the case3 sample and changed the
imgsrc path for the itemquery map to:
"/cgi-bin/mapserv.exe?map=d:\inetpub\wwwroot\iqdir\iq.map&item=ct
y_name&value =[value]&mode=itemquery&mapext=shapes"
height="300"width="300"
The Test.htm page comes up and provides the user with a list of
counties. When one of the counties is selected and the user
selects GO! the following statement results:
The three field values populate correctly. The full extent map
comes up correctly. But the itemquery map only comes up as a box
with a baby X icon in the left corner.
How can I get my itemquery map to appear?
Thanks so much in advance and I look forward to any help.
Gracias.
Sonia Dickerson
MN Department of Agriculture
90 West Plato Boulevard
St. Paul, MN 55107-2094
phone: 651-284-3597
fax: 651-282-2442
sonia.dickerson at state.mn.us
"If you wait until the wind and weather are just right
you will never plant anything and never harvest anything"
------------- End Forwarded Message -------------
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010516/14530b38/attachment.html
