[mapserver-users] PDF output, what about?
Andréas M. Winter
winter at freytagberndt.at
Tue May 22 09:43:31 EDT 2001
PDF is fine, SVG would be better when dealing with vector graphics on
the web.
have al look at http://www.karto.ethz.ch/cgi-bin/projection.pl and
http://www.carto.net/papers/svg . first is a projection tool with pdf
AND svg output, second a paper about the benefits of svg for
cartography!
regards
andré
____________________________________________
andréas m. winter - freytag & berndt
content management - new media & internet
austria a1230 wien brunner str 69
tel +43.1.869.90.90.38
fax +43.1.869.90.90.62
mailto:winter at freytagberndt.at
-----Ursprüngliche Nachricht-----
Von: Carlo A. Bertelli [mailto:bertelli at charta.acme.com]
Gesendet: Dienstag, 22. Mai 2001 12:45
An: mapserver-users at lists.gis.umn.edu
Betreff: [mapserver-users] PDF output, what about?
Hello fellows,
GIF and PNG output are very good for mapserver, as the browser does not
ask
for a plug-in to see maps, but when you need printing, screen-resolution
pictures are not so good.
I think mapserver should use a PDF library to provide PDF output for
printing purposes. Say, when you have the map you need (thematic
mapping,
scale, and so on), you would click on a 'PDF' button and presto! you get
a
print-ready image you could enhance or incorporate in documents.
Ciao
Carlo
Carlo A. Bertelli
Charta servizi e sistemi per il territorio e la storia ambientale
srl
Dipendenze del palazzo di Clemente Doria,
vc. alla Chiesa della Maddalena 9/2 16124 Genova
(Italy)
tel. +39 010 2475439 fax +39 010 2475439 cell: 0333
2298345
e-mail: bertelli at charta.acme.com http://www.charta.acme.com
