[mapserver-users] ArcSDE 8.1 for Linux
Stephen Lime steve.lime at dnr.state.mn.us
Tue May 29 15:47:49 EDT 2001
I'll add code to the configure script to allow you to specify a version with the
default being 8.0. You can work around that by editing configure and changing
all instances of 8.0 to 8.1 and configuring as normal. You'll still run in to other
issues with network functions. I've just recently got my hands on the linux
client libs and will try and fix this soon. You're welcome to play with the
Makefile produced by configure to try and get it working as well. Let me know
if you have any luck.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Andrea Goethals <andreag at geoplan.ufl.edu> 05/22/01 03:07PM >>>
Hi List,
I have ArcSDE 8.1 which theoretically runs on Linux. I wanted to try it
with mapserver to try to take advantage of the spatial analysis you can do
with ArcSDE's C or Java APIs. I installed the client libraries on my machine
but  am having trouble compiling Mapserver with it. From what I can tell of
my configure script (from mapserver 3.3.011) it is expecting ArcSDE to be
version 8.0.  I downloaded the mapserver nightly build and it appears that the
newer configure script expects version 8.0 too.
Anyone have some experience and/or suggestions for how to compile this?
Thanks,
Andrea
| Andrea Goethals         |
| andreag at geoplan.ufl.edu |
| GeoPlan Center          |
| University of Florida   |
