[mapserver-users] labelitem and filteritem
Richard Greenwood
Rich at GreenwoodMap.com
Fri Nov 2 11:04:36 EST 2001
At 12:18 PM 11/2/2001 +0100, you wrote:
>Hi All,
>Does anyone on the list know why I cann't use both labelitem and filteritem
>at the same time with CGI 3.5?
>If I use filteritem, the tag labelitem has no effect at all and if I detele
>the labelitem tag then I can use filteritem with no problem
>Does it have any sense?
I may not understand your question, but anyway - You can use both labelitem
and filteritem, but filteritem works with an itemquery, so if you are not
in itemquery mode, no results wiil be found, and hence nothing will be labeled.
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
