[mapserver-users] Polygon Questions
Ed McNierney
ed at topozone.com
Thu Nov 8 12:07:37 EST 2001
Frank -
I've done a moderate amount of shapefile generation/modification with
shapelib and used the results in MapServer. I've found nothing that
contradicts your comments below about shapefiles.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Thursday, November 08, 2001 9:48 AM
To: Stephen Woodbridge
Cc: MapServer List
Subject: Re: [mapserver-users] Polygon Questions
Stephen Woodbridge wrote:
> Hi again,
> Does mapserver, or shapefiles for that matter, care if polygon points
> are ordered clockwise or counter-clockwise?
> In shapefiles, a polygon can be in multiple parts?
> 1) Does this mean multiple smaller closed polygons which constitue a
> large object?
> 2) A large polygon, where the additional parts represent islands in
> the larger one.
> 3) something else all together :)
> -Stephen Woodbridge
Stephen,
o I don't think MapServer cares about the direction of polygon vertices.
o The Shapefile spec is specific about the ordering of vertices in the
rings based on whether they are exterior or interior rings; however,
it doesn't appear that ESRI products depend on this, and many
generators
of shapefiles are careless in generation (notably my own Shapelib!).
o Shapefile polygons can be multiple islands as well as having holes in
islands. Both options are correctly handled by MapServer.
I could be wrong on any of the above, but I am pretty sure I am right.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
