[mapserver-users] a question
Joop de Vries
Joop.de.Vries at delft-plaza.nl
Mon Nov 12 07:38:56 EST 2001
i am trying to compile mapscript on a IBM RS6000 with AIX4.3. I
installed freetype1.3.1 and this error occures, can anybody help please?
regards Joop
mapcript_wrap.c
Running Mkbootstrap for mapscript ()
chmod 644 mapscript.bs
LD_RUN_PATH="/mapserver:/mapserver/gd-1.2:/mapserver/gdft:/lib"
ld -o blib/arch/auto/mapscript/mapscript.so -bhalt:4 -bM:SRE
-bI:/usr/opt/perl5/lib/5.00503/aix/CORE/perl.exp -bE:mapscript.exp -b
noentry -lc -bnoquiet mapscript_wrap.o -L/mapserver -lmap
-L/mapserver/gd-1.2 -lgd -L/mapserver/gdft -lgdft -lttf -lm
(ld): halt 4
(ld): savename blib/arch/auto/mapscript/mapscript.so
(ld): filelist 7 3
(ld): setopt noprogram
(ld): noentry
NOENTRY: There is no entry point.
(ld): lib /usr/lib/libc.a
(ld): i mapscript_wrap.o
(ld): lib /mapserver/libmap.a
(ld): lib /mapserver/gd-1.2/libgd.a
(ld): lib /mapserver/gdft/libgdft.a
(ld): lib /usr/lib/libttf.a
(ld): lib /usr/lib/libm.a
LIBRARY: Shared object libc.a[shr.o]: 2262 symbols imported.
LIBRARY: Shared object libc.a[meth.o]: 2 symbols imported.
LIBRARY: Shared object libc.a[aio.o]: 11 symbols imported.
LIBRARY: Shared object libc.a[pse.o]: 78 symbols imported.
LIBRARY: Shared object libc.a[dl.o]: 4 symbols imported.
LIBRARY: Shared object libc.a[pty.o]: 1 symbols imported.
FILELIST: Number of previously inserted files processed: 7
(ld): imports /usr/opt/perl5/lib/5.00503/aix/CORE/perl.exp
IMPORTS: Symbols imported from import file
/usr/opt/perl5/lib/5.00503/aix/CORE/perl.exp: 1440
(ld): exports mapscript.exp
EXPORTS: Symbols exported: 1
(ld): resolve
RESOLVE: 4205 of 11494 symbols were kept.
(ld): addgl /usr/lib/glink.o
ADDGL: Glink code added for 79 symbols.
(ld): er full
ld: 0711-318 ERROR: Undefined symbols were found.
The following symbols are in error:
Symbol Inpndx TY CL Source-File(Object-File) OR
Import-File{Shared-object}
RLD: Address Section Rld-type
Referencing Symbol
.TT_Open_Face [30] ER PR
gdttf.c(/mapserver/gdft/libgdft.a[gdttf.o])
000003c0 .text R_RBR [96]
<.fontFetch>
.TT_Get_Face_Properties [32] ER PR
000003f8 .text R_RBR [96]
<.fontFetch>
.TT_New_Instance [34] ER PR
00000408 .text R_RBR [96]
<.fontFetch>
.TT_Set_Instance_Resolutions [36] ER PR
0000042c .text R_RBR [96]
<.fontFetch>
.TT_Set_Instance_CharSize [38] ER PR
00000464 .text R_RBR [96]
<.fontFetch>
.TT_Get_Instance_Metrics [40] ER PR
<.fontFetch>
<.fontFetch>
0000048c .text R_RBR [96]
<.fontFetch>
.TT_Get_CharMap_Count [42] ER PR
00000498 .text R_RBR [96]
<.fontFetch>
.TT_Get_CharMap_ID [44] ER PR
000004d4 .text R_RBR [96]
<.fontFetch>
.TT_Get_CharMap [46] ER PR
00000520 .text R_RBR [96]
<.fontFetch>
0000054c .text R_RBR [96]
<.fontFetch>
00000570 .text R_RBR [96]
<.fontFetch>
000005a8 .text R_RBR [96]
<.fontFetch>
.TT_Done_Instance [52] ER PR
000006b4 .text R_RBR [98]
<.fontRelease>
.TT_Close_Face [54] ER PR
000006c0 .text R_RBR [98]
<.fontRelease>
.TT_New_Glyph [62] ER PR
00000820 .text R_RBR [102]
<.glyphFetch>
.TT_Char_Index [64] ER PR
000008d8 .text R_RBR [102]
<.glyphFetch>
.TT_Load_Glyph [66] ER PR
000008f8 .text R_RBR [102]
<.glyphFetch>
.TT_Get_Glyph_Metrics [68] ER PR
00000920 .text R_RBR [102]
<.glyphFetch>
.TT_Get_Glyph_Outline [70] ER PR
00000948 .text R_RBR [102]
<.glyphFetch>
.TT_Transform_Outline [72] ER PR
0000095c .text R_RBR [102]
<.glyphFetch>
.TT_Done_Glyph [74] ER PR
00000d8c .text R_RBR [104]
<.glyphRelease>
.TT_Get_Glyph_Pixmap [78] ER PR
00000ed0 .text R_RBR [108]
<.bitmapFetch>
.TT_Get_Glyph_Bitmap [80] ER PR
00000eec .text R_RBR [108]
<.bitmapFetch>
.TT_Init_FreeType [84] ER PR
000016cc .text R_RBR [120]
.imageStringTTF
ER: The return code is 8.
make: 1254-004 The error code from the last command is 8.
