[mapserver-users] Question on command: "Mapserv -v"
jtang at gmu.edu
jtang at gmu.edu
Wed Nov 14 22:32:21 EST 2001
Lists,
I met a problem with the mapserver 3.3 when trying using
command "mapserv -v".
scs 100% mapserv -v
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
>From the web document "Raster Howto", it says that this command will
return something as "mapserver version 3.5 OUTPUT=PNG OUTPUT=JPEG...."
I got different answer. Is it because they are different version?
Thank you.
Jiang Tang
