[mapserver-users] maporaclespatial
DebasishS at riskinc.com
Thu Nov 15 05:47:35 EST 2001
Which version of Mapserver you are using ??
thanks
Debasish.
Joel Schlagel
<joel at crrel.usace.army.mil> To: <mapserver-users at lists.gis.umn.edu>
Sent by: cc:
owner-mapserver-users at lists.g Subject: [mapserver-users] maporaclespatial
is.umn.edu
11/15/01 03:32 AM
Please respond to
Joel.D.Schlagel
i haven't seen anyone mention it yet, so i'll try to be the first happy
mapserver user to thank Rodrigo Cabral for all his work on the
maporaclespatial code. we've been using it for about a week and its
worked perfectly.
we used oracle shp2sdo utility to convert shape files to oracle
loader format. we loaded 2.7 million texas tiger 2000 road segments as a
test data set, indexed with oracle's recommended tile size, and have been
viewing and querying with mapserver with no problem.
the nicest part of using oracle spatial with mapserver is being able to
pass standard sql queries either from the map file or by modifiying
the map_layer_data_ .. these can be attribute queries, oracle
spatial queries on geometry, or a combination. i included a couple of
lines from a map file in case anyone's interested ...
# counties from oracle spatial
LAYER
NAME counties
TYPE polygon
STATUS default
MAXSCALE 1000000
CONNECTIONTYPE oraclespatial
CONNECTION 'u/p at sdo'
DATA "GEOM from tx_cty"
CLASS
NAME 'county'
COLOR 220 224 230
OUTLINECOLOR 0 0 0
END
# only draw interstates (hwi) from all roads
LAYER
NAME tx1
TYPE line
STATUS default
MAXSCALE 200000
MINSCALE 80000
DATA "GEOM from (select * from tx_rds where CFCC = 'hwi')
CLASS"
COLOR 200 0 0
END
END
# draw 1/2 degree x 1/2 degree square area from roads
LAYER
NAME tx2
TYPE line
STATUS default
DATA "GEOM from (select * from tx_rds where mdsys.sdo_relate
(tx_rds.geom, mdsys.sdo_geometry (2003, null,
null,mdsys.sdo_elem_info_array
(1,1003,3), mdsys.sdo_ordinate_array (-100, 30.5, -99.5 , 31)),
'mask=ANYINTERACT querytype=WINDOW') = 'TRUE')"
CLASS
COLOR 200 0 0
END
END
joel
