[mapserver-users] QUERYONLY?
Stephen Lime steve.lime at dnr.state.mn.us
Mon Nov 19 14:47:03 EST 2001
My bad, it's acually TYPE QUERY. How the query is handled is dependant on the underlying shape type not the LAYER TYPE so that setting was moved. The 3.5 docs are mostly correct except that QUERYONLY should be QUERY.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Obe, Regina     DND\MIS" <Regina.Obe.PFD at ci.boston.ma.us> 11/14/01 04:27PM >>>
I got a similar error too (not sure if these two are related) - using the
mapserv35_png_ogr for win32 build 11/7/2001.  This was using the itasca demo
app for 3.5 (I downloaded 10/17/2001) (and my other apps which worked with
prior version of the mapserv 3.5 exe also give similar behavior.  So I was
wondering if an interim change to specs had taken place during the 3.5
between 10/19 and now.
The prior version I was using was a build around 10/19/2001.
I get an error
getSymbol(): Symbol definition error. (END):(96)
(I did modify it a bit to work with my configuration so not the exact demo -
but just minor changes to paths)
When trying to use the itasca demo app - dated around 10/17/2001
-----Original Message-----
Sent: Wednesday, November 14, 2001 11:29 AM
To: steve.lime at dnr.state.mn.us
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] QUERYONLY?
> It's STATUS QUERY, not QUERYONLY.
also tried that, but:
Warning: MapServer Error in getSymbol(): (QUERY):(64)
LAYER
    NAME buses
    METADATA
        "DESCRIPTON" "Rec Buses"
        "RESULT_FIELDS" "ROUTE_ID"
    END  <---------------------------------------- Line 64
    STATUS QUERY
        TYPE LINE
        LABELITEM "NOMBRE"
    DATA r_bus_utm56
    CLASS
        NAME "Rec Buses"
        TEMPLATE "test_draw_map.phtml"
                LABEL
                        COLOR 238 238 140
                        FONT arial_V
                        TYPE truetype
                        ANGLE AUTO
                        ANTIALIAS
                       SIZE 7
                END
        COLOR 200 150 54
    END
    TOLERANCE 10
END
V. <v at w.cl>
