AW: [mapserver-users] How do they do that???
Geo-IT-GmbH info at geo-it.com
Thu Nov 22 03:21:23 EST 2001
Hi Steve,
we are also experimenting with Java applets to generate MapServer requests
(using Ross Searles ArcView utility). Can You please send us the code for
Your landview application. We are working on the combination of Java applets
and the MapServer oraclespatial option.
Thanks in advance,
Daniel
Geo-IT GmbH   -   Geoinformatik, IT-Services
Guggenberg 3, D-82380 Peissenberg
Tel: 08803-498372, Fax: 08803-498373
eMail: info at geo-it.com  -  Homepage: http://www.geo-it.com
> -----Ursprüngliche Nachricht-----
> Von:	Stephen Lime [SMTP:steve.lime at dnr.state.mn.us]
> Gesendet am:	Mittwoch, 21. November 2001 20:23
> An:	Chip.Hankley at GASAI.Com; mapserver-users at lists.gis.umn.edu
> Betreff:	Re: [mapserver-users] How do they do that???
> Well I can speak to landview since I wrote it. In short it uses a small
> applet to do the display and mouse event handling and manages all of the
> coordinate information using a javascript library. Then I use a public
> method of the applet to swap the image being displayed. The image urls are
> actually calls to the MapServer (mode=map). This could also be done using
> DHTML (i.e. layers) IF you use frames or a single page design with
> absolute positioning of layers. Absolute positioning is fine in a frame
> with nothing else or if you have a design with nothing that will change
> size to the left and above your map. Personally I like the freedom the
> applet gives you.
> All of my code is available on request, but it really needs more
> documentation (like everything else).
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Hankley, Chip" <Chip.Hankley at GASAI.Com> 11/21/01 10:33AM >>>
> I've seen a few MapServer apps where, after a navigation event, the entire
> page doesn't reload... only the map window.
> for example:
> http://maps.dnr.state.mn.us/landview/
> http://144.92.235.164/orthofinder/
> How do they do that? Is this using Java? One site uses frames and the
> other
> doesn't...
> TIA
> Chip Hankley
