[mapserver-users] QUERYONLY?
Obe, Regina DND\MIS Regina.Obe.PFD at ci.boston.ma.us
Mon Nov 26 09:12:23 EST 2001
David,
I tried your suggestion - using the latest win32 PNG build of mapserv on the
site and changing the lines to read
SYMBOL
  NAME 'circle'
  TYPE ELLIPSE
  POINTS 1 1 END
  FILLED = TRUE
END
 now I get the following error.
loadSymbol(): Unknown identifier. (TRUE):(95)
-----Original Message-----
From: Fawcett, David [mailto:david.fawcett at moea.state.mn.us]
Sent: Wednesday, November 14, 2001 6:24 PM
To: 'v at w.cl'; steve.lime at dnr.state.mn.us; 'Obe, Regina DND\MIS'
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [mapserver-users] QUERYONLY?
Regina,
	I don't believe that the getSymbol() error that you are receiving is
related to Vinko's error below.
	You are getting an error because the syntax for the SYMBOL object
has changed. Look at line 96 of your map file:
	#This is the old syntax
	SYMBOL
	   NAME  'circle'
	   TYPE  ELLIPSE
	   POINTS  1 1 END
	   FILLED
	END
      #This is the new syntax
	SYMBOL
	   NAME  'circle'
	   TYPE  ELLIPSE
	   POINTS  1 1 END
	   FILLED = TRUE                    #You need to add '= TRUE'  to
this line
     END
Once you make this change, you will most likely get an error in line 137
related to the layer type polyline.  You can find a previous post from Steve
Lime regarding these changes at:
http://mapserver.gis.umn.edu/majordom_lists/archives/mapserver-users/html/01
10/msg00374.html
I was just in the process of writing up a list of needed revisions for the
3.5 Demo for Steve.
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: 	Obe, Regina     DND\MIS[SMTP:Regina.Obe.PFD at ci.boston.ma.us]
> Sent: 	Wednesday, November 14, 2001 4:27 PM
> I got a similar error too (not sure if these two are related) - using the
> mapserv35_png_ogr for win32 build 11/7/2001.  This was using the itasca
demo
> app for 3.5 (I downloaded 10/17/2001) (and my other apps which worked with
> prior version of the mapserv 3.5 exe also give similar behavior.  So I was
> wondering if an interim change to specs had taken place during the 3.5
> between 10/19 and now.
> The prior version I was using was a build around 10/19/2001.
> I get an error
> getSymbol(): Symbol definition error. (END):(96)
> (I did modify it a bit to work with my configuration so not the exact demo
> but just minor changes to paths)
> When trying to use the itasca demo app - dated around 10/17/2001
