[mapserver-users] compile problem
Doyon, Jean-Francois Jean-Francois.Doyon at ccrs.nrcan.gc.ca
Tue Nov 27 15:58:26 EST 2001
Jim,
Ah yes, a common re-occuring problem ... If I remember correctly, go into
the Makefile and look for the line CC= ... you'll find that the "cc" command
appears twice ... remove one of them ... or was it configure? I forget,
anyways there's a duplicate "cc" in onoe of the files used to either
configure or build ... You'll find the exact solution probably in the
archives as this has been mentionned before.
Cheers,
J.F.
-----Original Message-----
From: Jim Burnett [mailto:jimburnett at ntelos.net]
Sent: Wednesday, November 28, 2001 2:59 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] compile problem
I setup a new server a few days ago and now I am trying to install
mapserver, and mapscript.
Same setup, using same downloaded file that were on my other web server. The
only dif is I am using Slackware8, instead of 7.1.
Apache1.3
Php4.0.5
GD1.8
Nightly source that works on other server
I get this error:
cc: cannot specify -o with -c or -S and multiple compilations
-jim-
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011127/44c3d2d2/attachment.html
