[mapserver-users] cahnging Mapfile from 3.4 to 3.5
Stephen Lime steve.lime at dnr.state.mn.us
Thu Oct 11 10:42:09 EDT 2001
What does the mapfile look like? The error probably stems from a layer with no DATA
defined and no inline features that you were using to render features on-the-fly with
from MapScript. I'll throw a test in to skip those. The default layer type is a shapefile
which is why you see the error.
Query parameters (i.e. TEMPLATE) have moved into CLASS objects. You can also
define a global TEMPLATE at the layer level. The test suite:
  http://maps.dnr.state.mn.us/mapserver_demos/tests3.5
shows how this configuration looks.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Wolfgang W. Wasserburger" <wasserburger at plan.at> 10/11/01 09:24AM >>>
Listers,
today I tried to change a existing (and working) MAP-File from 3.4 to 3.5
I got the following Error: msOpenSHPFile(): Unable to access file. No (NULL)
filename provided.
Does anybody know, what that is meaning.
I used the nightly build from 1.10. under NT.
Another question: how to build querys after thorwing out the Query ... End
section?
Gtreetings from Vienna, Austria
