[mapserver-users] Shapefiles - different formats?
Lyndon Zimmermann lyndon.zimmermann at adelaide.edu.au
Mon Oct 15 01:29:02 EDT 2001
Janet,
I don't think ArcView looks at the .prj file at all, you can have any
rubbish in it, UNTIL you want to use a reprojection tool. I would almost
classify it as metadata. I would try reprojecting your "functional"
shapefile and see how it copes with the .prj file.
ArcGIS, however, actually looks at the .prj file (if it exists) and
tries a reproject on the fly with it.  Your results will vary according
to the validity of the .prj file.  I don't think MapServer uses the .prj
file either, so what you see in MapServer and ArcView will be different
to what you see with ArcGIS.
Lyndon Z
Janet Ciavarelli wrote:
> Hmmmm, it still doesn't work. I now have the .prj file as well, but still the .shp,.shx and .dbf I created using mapscript together with the .prj does not work in ArcMap 8.1 but works fine in ArcView 3.2.
> Janet Ciavarelli
> GIS Programmer/Analyst
> City of Kamloops, BC
> (250) 828-3393
> jciavarelli at city.kamloops.bc.ca
> >>> "Ed McNierney" <ed at topozone.com> 10/05/01 09:58am >>>
> Janet et al. -
> Janet seems to have found the problem.  It appears that ArcGIS 8.1
> *requires* a .prj file (which describes the shapefile's projection, not
> an ArcView project), which (all else being equal) is a pretty good
> thing.  ArcView 3.2 does not require .prj files.
> PRJ files are simple text files that probably look familiar to PROJ
> users - here's the contents of a simple one.
> proj=utm
> zone=15
> units=m
> ellps=GRS80
>         - Ed
> Ed McNierney
> Chief Mapmaker
> TopoZone.com
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: imap at chesapeake.net [mailto:imap at chesapeake.net]
> Sent: Friday, October 05, 2001 12:54 PM
> To: mapserver-users at lists.gis.umn.edu
> Cc: Janet Ciavarelli; Ed McNierney
> Subject: Re: [mapserver-users] Shapefiles - different formats?
> ArcView will read the 3 files just fine.  You have to create
> or Open a New Project, then Add Layer, then browse to the
> dir where your shapefiles are, then pick one.
> A somewhat related comment, There are actually a other
> files that sometimes accompany a shapefile.
> .shp, .shx, .dbf  (main 3 files)
> .sbn, .ixs, .mxs  (???  mystery files)
> .prj, .apr        (project files I think)
> I think the .ixs and .mxs are geocoding indexes
> and .sbn??? who knows.   I'd really like to know
> the layout of these other files.  I am not sure
> if they come from ArcInfo, or what?  I see a few
> 3rd party companies create these files within their
> ArcView Format, but it may be a proprietary aspect
> of Arc???  If anyone has info, please reply an email.
> Anyway, The .apr(.prj?) are in ascii and is a long
> list of name/value pairs, so a script should be able
> to generate/manipulate OK.
> Regards,
> Chris Stuber (mapsurfer)
> Silicon Mapping Solutions, Inc
> (410)257-3187
> > Hi Ed,
> >    I see what the difference is now. I went into ArcCatalog and
> created an empty shapefile, and I looked in explorer. It creates 4
> files! Not just the 3 files that it used to use (.shp, .shx, .dbf).
> > I've attached all the four files. So that explains why ArcView 3.2 can
> open the file though. Cause it finds the 3 files and just ignores the
> 4th. But ArcMap 8 wants all 4 files. The 4th file is a .prj file. I will
> have to find out what's in it and get my script to create that as well.
> Also, maybe that utility you advised me to grab will create it. I will
> check when I get time which my be a long time from now.
> > Thanx for your help. Janet.
> > >>> "Ed McNierney" <ed at topozone.com> 10/04/01 05:49pm >>>
> > Janet -
> > Can you create an empty point shapefile in 8.1 and send that to me,
> too?
> > I don't have 8.1, but I can take a look at the shapefile to see if
> > there's anything different.
> >         - Ed
> > From: Janet Ciavarelli [mailto:Jciavarelli at city.kamloops.bc.ca]
> > Sent: Thursday, October 04, 2001 4:11 PM
> > To: Ed McNierney
> > Subject: RE: [mapserver-users] Shapefiles - different formats?
> > Yes, same symptom even with records added.
> > >>> "Ed McNierney" <ed at topozone.com> 10/04/01 01:10pm >>>
> > Janet -
> > Do you get the same symptom when you add records to the shapefile?
> >         - Ed
> > Sent: Thursday, October 04, 2001 4:03 PM
> > To: Ed McNierney
> > Hi Ed,
> >    Here's a copy of the shapefile. BTW, it is an empty one but it
> should
> > be successfully able to open empty shapefiles as well. We've tried it
> > with both empty and un-empty ones and get the same results: it opens
> > find in AV 3.2 but errors out in AV 8.1
> > Janet.
> > Janet Ciavarelli
> > (250) 828-3393
> > >>> "Ed McNierney" <ed at topozone.com> 10/04/01 12:38pm >>>
> > Janet -
> > I certainly expect 8.1 reads 3.2 shapefiles (at least, in general).
> > Perhaps it's more likely that you're creating a slightly out-of-spec
> > shapefile that's being tolerated by 3.2, but 8.1 is being fussier
> about.
> > There's a tool called shpfix in the GDAL distribution that might
> > possibly help clean up the file.  If you'd like to email me the
> > shapefile I'll take a look at it.
> >         - Ed
> > Ed McNierney
> > Chief Mapmaker
> > TopoZone.com
> > ed at topozone.com
> > (978) 251-4242
> > Sent: Thursday, October 04, 2001 2:17 PM
> > To: mapserver-users at lists.gis.umn.edu; teb at mallit.fr.umn.edu
> > Subject: [mapserver-users] Shapefiles - different formats?
> > Sort of off topic, but thought I'd ask anyways in case anyone knows. I
> > have written a perl/mapscript to create a shapefile. I can view the
> > shapefile in ESRI  ArcView 3.2 fine. But when I try to view it in ESRI
> > ArcView 8.1, I get an error. Is anyone out there aware of any
> > differences between shapefile formats between different products?
> > Janet.
> > Janet Ciavarelli
> > (250) 828-3393
> >    shapev8.dbf       Type: unspecified type (application/octet-stream)
> >                  Encoding: base64
> >               Description: dBase 3 database
> >    shapev8.prjName: shapev8.prj
> >               Type: Plain Text (text/plain)
> >    shapev8.shp    Type: ESRI Shapefile
> (application/x-unknown-content-type-shpfile)
> >               Encoding: base64
> >    shapev8.shx    Type: unspecified type (application/octet-stream)
> >               Encoding: base64
Lyndon Zimmermann
BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
"Bioenergy Atlas for Australia" Co-ordinator
University of Adelaide Agronomy and Farming Systems
C/- GISCA, 4th floor, 10 Pulteney St, Adelaide 5005
Dir (GISCA) +61-8-8303 3975 Switch (GISCA) 8303 3900 Mob 0414 91 4577
Fax (GISCA) +61-8-8303 3498 email lyndon.zimmermann at adelaide.edu.au
http://sg211.gisca.adelaide.edu.au/lzimmerm/zimm.htm
Biomass Energy Atlas Website (note it has moved!):
http://sg211.gisca.adelaide.edu.au/bioenergy_atlas/atlas_index.html
Unless otherwise stated, the content of this message and attachments may
be forwarded or quoted, with due acknowledgement.  No representation is
made that this email is free of viruses. Virus scanning is recommended
and is the responsibility of the recipient.
