[mapserver-users] ArcXML
imap at chesapeake.net imap at chesapeake.net
Tue Oct 16 13:59:34 EDT 2001
Paul,
I had problems compiling 'expat' which needed by one of the perl
modules (I think XML::Parser).  There was something left out of
the CVS distribution...  and wont compile.  Have you (or anyone)
had success compiling that?  I am doing most everything with
XML::Writer at the moment, but wanted to check out XML::Parser.
(so far w/o success).
The homepage for this project is http://expat.sourceforge.net/
Regards,
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc
(410)257-3187
Paul Ramsey wrote:
> It would probably require a dependency on libxml2, since doing the XML
> processing without some kind of DOM model gets unwieldy as the
> complexity of the structures goes up. If I was a C god, I would probably
> go this route. Sadly, I am not. :/
> Stephen Lime wrote:
> > or better yet add a arcXML parser module to the C source (using expeat?) and then it
> > could be made available via the CGI and all scripting interfaces...
> > Steve
> > Stephen Lime
> > Data & Applications Manager
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
>       __
>      | Paul Ramsey
>      | Refractions Research
>      | Email: pramsey at refractions.net
>      | Phone: (250) 885-0632
>      \_
