[mapserver-users] [Fwd: ASP Template]
Jamie Smedsmo jsmedsmo at gis.umn.edu
Tue Oct 23 14:45:17 EDT 2001
-------- Original Message --------
Subject: ASP Template
Date: Tue, 23 Oct 2001 16:32:55 -0200
From: Ualfrido Del Carlo Jr <ualfrido at engecorps.com>
To: "'mdp at lists.gis.umn.edu'" <mdp at lists>
Question 1:
I´m trying to open a ASP file at the query mode with the template comand in the map file, but it doesn´t work. Is there a limitation on Mapserv with ASP? The asp alone work fine, but not when I call it by the query mode. Can anyboby help me?
Question 2:
I need to select one City from a ComboBox or a TextBox and then show the polygon that matchs the name and center at the map. I have trying a couple of months but still without results.
I´m using Mapserv 3.5.
Thanks,
