[mapserver-users] map scale questions
Alex Rice alex_rice at arc.to
Mon Aug 5 20:56:57 EDT 2002
Hi, I think my mapserver scale output is wrong, and my scalebar
graphic is definitely skewed. I am stumped after looking at the
docs, tutorials and the mailing list archive.
I have a map table which viewed in MapInfo Pro tells me, the
Scale: 1 in = 3 mi (for this particular extent I am looking at).
So, in my mapfile MAP section I put
UNITS miles
and in my mapfile SCALEBAR section I put
UNITS miles
Then I view the same map & approx same extent in mapserver (OGR
reading mapinfo .tab), I get from mapserver scale = 1 : 5015 and
the scalebar renders as 1 bar = 0.16 mi. Clearly this is way off
from the 1 in = 3 mi which Mapinfo was saying.
But also mapserver scale 1:5015 does not equal the scalebar 1
bar = 0.16 mi !
If the scalebar is 1 inch, then 1 inch = 5015 inches = 418 feet =
0.079 mi.
So it's as if Mapinfo, the mapserver [scale] and the mapserver
scalebar image all are using different scales?
I am using no projections in my mapfile. I have saved all my
Mapinfo files with a common projection so I can avoid
reprojecting in mapserver. Do I need projections defined to make
the scale come out correctly?
I am just really confused about how to get mapserver to display
the same scale as Mapinfo Pro. Any suggestions would be
appreciated.
TIA
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
