[mapserver-users] combinations for ms3.6.1
Alex Rice
alex_rice at arc.to
Mon Aug 5 21:08:34 EDT 2002
On Monday, August 5, 2002, at 06:55 PM, Patricio Gigoux wrote:
> what is the best combination betwen ms3.6.1, php, gd, freetype,
> gdal, proj,
> perl, postgresql, posgis?
> thank you in advance
> Patricio
Hi, your question is not clear. The only items on that list one
could choose between are PHP Mapscript or Perl Mapscript.
Everything else has specific purpose and should be used or not
depending on your requirements:
Use ms3.6.1 is if you need mapserver :-)
Use PHP if you want PHP Mapscript.
Use Perl if you want Perl Mapscript.
Use GD, mapserver requires it, I think.
Use Freetype if you want True Type labels.
Use GDAL if you want support for reading in more raster formats.
Use OGR (part of GDAL) if you want support for reading in more
vector formats, e.g. Mapinfo TAB.
Use PROJ if you want to use different coord systems and want
mapserver to be able to reproject layers.
I hope this helps, if not maybe you can rephrase the question.
Regards,
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
