[mapserver-users] libpdf.so.1: cannot open shared object file
Antti.Roppola at brs.gov.au
Mon Aug 5 22:03:11 EDT 2002
Albin,
Have you tried running ldd against ./mapserv to see where the compiled
object thinks libpdf is located?
ldd ./mapserv
Also, have a look at the Wiki where there is a set of instructions for
Debian Woody including PDFlib support:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebianLinux
If you are not interested in PHP Mapscript, you can probably ignore all
the stuff involving Apache and PHP.
You may also want to try the packages Paul Baker has built. :o)
Cheers,
Antti
-----Original Message-----
From: Albin Blaschka [mailto:albin.blaschka at sbg.ac.at]
Subject: [mapserver-users] libpdf.so.1: cannot open shared object file
Hello out there!
I compiled Mapserver 3.6, with following configure-options:
--with-gd --with-proj --with-pdf
'configure' and 'make' brought *no* errors. The binary 'mapserv' *is*
created. But when I want to test it with ./mapserv (like it is said in the
documentation) I get the following error:
'error while loading shared libraries: libpdf.so.1: cannot open shared
object file: No such file or directory'
The files lay in /usr/local/lib/libpdf.a, libpdf.la, libpdf.so
My box:
Debian 3.0 Woody
MapServer 3.6.1
Is there help possible ?
Albin
