[mapserver-users] Re:acetate logo & inline features / text st
ring
Hankley, Chip
Chip.Hankley at GASAI.Com
Tue Aug 6 13:35:59 EDT 2002
...if you are using PHP-MapScript, something along the following lines will
work. I have used this function to embed numerous images... north arrows,
copyright information, etc. Basically, you need an image to embed, then play
around with the $img_x and $img_y to get it to the right spot.
Cheers!
Chip Hankley
PHP-Mapscript example of using the embed_picture function
//Embed the scalebar into the main image before it's drawn
$sb_url=".." . draw_scalebar($map);
embed_picture($map, $Cur_Extent, $img, "$sb_url", ($map->width / 2), 10);
//Now embed the north arrow into the main map
embed_picture($map, $Cur_Extent, $img, "../MapSymbols/NorthW.gif", 20,
($map->height - 20));
function embed_picture($map, $Cur_Extent, $img, $img_name, $img_x, $img_y) {
// Function Parameters:
// $map - the map object
// $Cur_Extent (array) - extent of current image, xmin, ymin, xmax, ymax
// $img - image object generated by $map->draw
// $img_name - the name (and path) of the image to embed
// $img_x - x pixel coordinates of location in $img to embed $img_name
// $img_y - y pixel coordinates of location in $img to embed $img_name
//Create a new Point Layer
$layer = ms_newLayerObj($map);
$layer->set("name", "legend");
$layer->set("type", MS_LAYER_POINT);
$layer->set("status", 1);
//Create a new Class for the Layer
$class = ms_newClassObj($layer);
$class->set("name", "legendclass");
$symb = $map->getSymbolByName($img_name);
$class->set("symbol", $symb);
//symbols/legend.gif
//Place the point so that it is 221 pixels IN and 301
// pixels UP from the lower left hand conrner of
// the image. We are using an image that is 300 x 37
// pixels... this should put the image just inside
// the rendered image.
$ImgWidth = $map->width;
$ImgHeight = $map->height;
$Pixel_X = ($Cur_Extent[2] - $Cur_Extent[0]) / $ImgWidth;
$Pixel_Y = ($Cur_Extent[3] - $Cur_Extent[1]) / $ImgHeight;
$Spot_X = $Cur_Extent[0] + $img_x * $Pixel_X;
$Spot_Y = $Cur_Extent[1] + $img_y * $Pixel_Y;
$point = ms_newpointObj();
$point->setXY($Spot_X, $Spot_Y);
$point->draw($map,$layer,$img,'legendclass',undef);
$layer->draw($img);
