[mapserver-users] Wanted: Projection for the reference map
Richard Greenwood Rich at GreenwoodMap.com
Wed Aug 7 18:21:50 EDT 2002
Sort of related to the projection issue is a "wish list" item for the
reference map that I've been thinking about -  It would be nice to have
different reference maps for different scales or locations. e.g. the user
starts with a reference map of the united states, but when they zoom into
Rhode Island they would get a reference map of RI. Obviously there are
probably some pretty straight forward ways to achieve this, but if somebody
is going to re-work the reference map then I'd throw that out for
consideration.
Rich
At 04:35 PM 8/7/2002 -0400, you wrote:
>Interesting that this just came up because I ran into this same
>problem just yesterday. The problem I had was not so much wanting the
>reference map to be projected, but the fact that I had created it in
>one projection and had later changed the mapfile's projection
>parameter to a different projection. If the reference map is not
>created in the same projection as the mapfile projection is does not
>work. It would be nice to be able to say WHAT projection the
>reference map was made in so you don't have to recreate the reference
>map if you change the projection parameters on the mapfile.
>On 7 Aug 2002 at 14:32, Steve Lime wrote:
> > You've not missed anything, that support is not available. Nor do I see
> > this being add in the near term due
> > to the ton's of other work going on. This should be added as a feature
> > request to Bugzilla so that the idea
> > is not lost. That said, there are other possibilties:
> > There is nothing that says that you can't use two different MapServer
> > applications on the same page. In
> > reality you can mimic a reference map using a second mapping
> > application. If you look closely at our
> > Recreation Compass (http://www.dnr.state.mn.us/maps/compass.html)
> > application you'll see we have
> > done just that. I wanted a reference map that would display a filled
> > box sometimes, a marker symbol
> > when the was too small, and nothing when the box was too large (eg. you
> > didn't need the reference map).
> > Prior to 3.6.1 you couldn't do this the the reference map object. The
> > solution was to use a second
> > little application. Worked like a charm and required on a small bit of
> > javascript. I would imagine you could
> > do the same thing with a reference map in a second projection. You'd
> > just have to use lat/lon as a go
> > between coordinate system. Worth a look if this is functionality you
> > need ASAP.
> > Steve
> > Stephen Lime
> > Data & Applications Manager
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
> > >>> Havard Tveite <havard.tveite at ikf.nlh.no> 08/01/02 06:25AM >>>
> > I can not find a possibility to describe a projection for the
> > Reference Map Object in the Mapserver documentation. Have I
> > overlooked something?
> > In my opinion it would be very useful and practical to be
> > able to use different projections for the reference map and
> > the main map.
> > This would, of course, in many cases lead to non-rectangular
> > outlines on the reference map, so one would have to determine
> > an appropriate level of detail for the outlines (from linear
> > interpolation between the four corner points to a smooth
> > rendering of the exact boundary curves). The lowest level
> > of detail would imply four coordinate transformations while
> > a high level of detail would lead to lots of coordinate
> > transformations.
> > The only effect I believe this would have on other elements
> > is that "EXTENT" in the reference map object would have to
> > be specified in the reference map coordinate system.
> > Håvard Tveite                      Phone:  +47 64948857
> > Department of Mapping Sciences     Fax:    +47 64948856
> > Agricultural University of Norway
> > POBox 5034, N-1432 Ås, NORWAY    http://www.nlh.no/ikf/
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
